How much time i need to create a website?
You can use this section of the forum to show your website created with Quick 'n Easy Web Builder to other users and invite feedback.
PLEASE READ BEFORE YOU POST or your post may be deleted!
This forum is for users to display their websites created with Quick 'n Easy Web Builder.
Please do not:
1) Ask any Quick 'n Easy Web Builder help or support related questions here.
2) Promote your website on somebody elses thread.
3) Start more than one thread about your site.
4) Say anything negative or mean about somebody's site. Constructive criticism is great and encouraged, but being deliberately nasty will not be tolerated.
5) Post any site that is not created with Quick 'n Easy Web Builder.
Marina
Post by Marina » Mon Jan 25, 2016 5:27 pm
I`m a beginner) And maybe it will be easier to pay for professional maker, than to do it by myself?
filmphotog
Re: How much time i need to create a website?
Post by filmphotog » Mon Jan 25, 2016 5:48 pm
Hi, I usually start small, adding one object at a time and preview in the browser. I think a simple theme is the best, especially if you add a couple of breakpoints to make the page mobile-friendly. It's good to see how much (or how little) will fit on a mobile screen.
Post questions in the forums, we are here to help if you needs it.
Centurion
Post by Centurion » Tue Jan 26, 2016 9:34 pm
Hi Marina,
It depends on what you want. Do you only need 1 page or multiple pages with buttons? Start in a weekend or when you have time to do so. If you're new you have to experiment a lot. So have I. Use some different templates and just play with it so you get some feel of it. I've seen different programs to build website with. So far I find Quick and Easy a very useful program. It has some strange things that should be changed or made easier but that's just me. What also helps is search on YouTube to see how others work with their software. Downside is I could not find any films on YouTube on Quick and Easy Webbuilder. Maybe I could make one but even I have a lot to learn.
Succes and ask if you have questions.
Marina
Post by Marina » Wed Jan 27, 2016 8:36 am
filmphotog wrote:Hi, I usually start small, adding one object at a time and preview in the browser. I think a simple theme is the best, especially if you add a couple of breakpoints to make the page mobile-friendly. It's good to see how much (or how little) will fit on a mobile screen.
Thanks for answer, so should i start from site on HTML?
Marina
Post by Marina » Wed Jan 27, 2016 8:40 am
Centurion wrote:Hi Marina,
Thank a lot) Maybe are there some easier programm for beginners? :)
filmphotog
Post by filmphotog » Wed Jan 27, 2016 8:59 am
You could start with a template or a new project in Quick n Easy. Use the preview button in Quick n Easy to preview in the browser often. You don't need to publish on the web until the site is ready.
Marina
Post by Marina » Thu Jan 28, 2016 9:09 am
You could start with a template or a new project in Quick n Easy. Use the preview button in Quick n Easy to preview in the browser often. You don't need to publish on the web until the site is ready.[/q
Thanks a lot)
Users browsing this forum: Google [Bot] and 2 guests
