My new website with blocks
You can use this section of the forum to show your website created with Quick 'n Easy Web Builder to other users and invite feedback.
PLEASE READ BEFORE YOU POST or your post may be deleted!
This forum is for users to display their websites created with Quick 'n Easy Web Builder.
Please do not:
1) Ask any Quick 'n Easy Web Builder help or support related questions here.
2) Promote your website on somebody elses thread.
3) Start more than one thread about your site.
4) Say anything negative or mean about somebody's site. Constructive criticism is great and encouraged, but being deliberately nasty will not be tolerated.
5) Post any site that is not created with Quick 'n Easy Web Builder.
Blitzer
Post by Blitzer »
About 100 content pages ...
http://www.wck.de
regards,
Blitzer
kgnoble
Re: My new website with blocks
Post by kgnoble »
Looks very good
Would you mind me asking how did you achieve the opening black graphic like opening curtains?
Keith
Blitzer
Post by Blitzer »
Take the extension "Preloading Screen".
- Background Color: # 222222
- Color 1: # 3498D8
- Color 2: # E74C3C
- Color 3: # F9C922
- Timeout: 0
- z-index: 9999
More at https://ihatetomatoes.net/create-custom ... ng-screen/
Blitzer
https://translate.google.com/translate? ... www.wck.de
kgnoble
Post by kgnoble »
Thank you - brilliant
Best
Keith
Looks good! I must say though it took long time to load. Maybe use image optimization tools.
Blitzer
Post by Blitzer »
It is important for me that mobile and desktop websites are supported. Extensive menus should be wrapped depending on the device resolution.
However, I attach the greatest importance to the content of my website. Technically, a lot is still feasible but not wanted ...
Blitzer
Cantenac
Post by Cantenac »
Looks great on the desktop, but on Android it's not quite working here (tested on Chrome + Samsung browsers).
- The graphic at the top of the home page isn't adjusting responsively (the width is being cut off).
- The menu bar is correctly switching to a drop-down menu, however the bar itself remains a horizontal bar that extends off the page.
Not sure if this is the result of a recent change, as the earlier reports from others don't mention these?
Blitzer
Post by Blitzer »
Thanks for the suggestions ...
@ morris
Done: Image optimization (long loading time)
@ Cantenac
Done: Graphic (the width is being cut off)
Done: Adjusted the width of the horizontal bar
Modification:
Layout grid
- full width
TRUE
Best
Blitzer
