no ftp connection
Raoul
no ftp connection
Post by Raoul » Mon Sep 01, 2014 11:23 am
I am trying to publish my site. But I get the log as you see below...
First I thought that I entered wrong login data ... but I tried it with the same data using cyberduck and then I can connect without a problem...
Thanks for help
*** START OF PUBLISH ***
Scanning publish folder...
Found 2 file(s).
Initializing FTP connection...
Connecting to verus.metanet.ch...
Using PASV mode.
FTP connection error: 221 Goodbye.
General exception!
Removing temporary files...
Publish failed!
*** END OF PUBLISH ***
Raoul
Re: no ftp connection
Post by Raoul » Mon Sep 01, 2014 12:22 pm
Strange - I just tested doing the same on my other mac and there it works...
Seems that on my macbookpro something with ftp publishing through qnewb is corrupt. Are there any config files for publishing or preference files (.plist) ?
Post by Pablo » Mon Sep 01, 2014 2:39 pm
This looks like a firewall issue. Make sure the software is configured (in your firewall) to allow incoming and outgoing connections, this is required for FTP passive mode.
wendie
Post by wendie » Thu Sep 17, 2015 10:59 pm
i am having the exact same problem. Previously I have had no problem publishing. My firewall is turned off so it can't be a firewall issue.
any suggestions?
Post by Pablo » Fri Sep 18, 2015 5:38 am
If it previously worked and your did not change anything then it's usually a server/host related issue.
http://www.quickandeasywebbuilder.com/f ... 10&t=36493
