Unfollow tag in Links
DoctorWeb
Post by DoctorWeb » Tue Feb 23, 2016 9:11 pm
Is there any information about, or way to add
rel="unfollow" tags in links to other web sites.
I can do this into an HTML object,
but cant seem to find any reference to it for adding a link to a text or image.
Does the program do it automatically.
I thought I had seen a true/false option in the Inspector at some time, but cant find it now.
Maybe the program does it automatically?
Many thanks
Re: Unfollow tag in Links
Post by Pablo » Wed Feb 24, 2016 8:19 am
I'm sorry there is currently no option to add this code.
For image links you can add the code yourself:
- right click the image
- select Object HTML
- Inside anchor
note that this option is only available if the image has a link.
DoctorWeb
Post by DoctorWeb » Wed Feb 24, 2016 12:29 pm
Thats brilliant, just the ticket. Using that Control-click manoeuvre (not something we do every day on a Mac) I can see Object HTML now, and its easy to add the tag either inside the HTML - just a question finding out whether its before / after etc it,
but I can struggle through that by trial and error.
I just read that Googly will strike you out off their rankings unless you have these tags in links. I was surprised to find its not an option already to add it. And oddly enough the Affiliates I want to link to all have no idea ahwre it should go at all - google don't even answer,
So thanks QWB support.
Post by Pablo » Wed Feb 24, 2016 1:29 pm
I have not heard about this. Where did you read this? If this an official Google statement?
I have found this, which seems to conflict with this information.
https://en.wikipedia.org/wiki/Nofollow
Users browsing this forum: No registered users and 2 guests
