can't write to file descriptor 9 error 28 no space left on device
xedni
Post by xedni » Wed Jan 17, 2018 7:32 pm
I've inserted a number of HTML5 videos to my site and now I can't publish locally. I have much more space on my home folder left than is made up by the videos. Is this a matter of /tmp folder being too small?
Re: can't write to file descriptor 9 error 28 no space left on device
Post by Pablo » Wed Jan 17, 2018 9:17 pm
Did you try to clean your tmp folder?
Note that this message is not generated by the software. It's a system error.
xedni
Post by xedni » Wed Jan 17, 2018 11:25 pm
Actually I think the error is generated by the software, not the system. I'd show you a screenshot if I could add an attachment (the dialogue indicates that it's a Qnewb error).
Does the software use the user's home folder for the tmp location, or the file system root (i.e. linux)?
Post by Pablo » Thu Jan 18, 2018 7:04 am
The message is displayed by the software but the system has generated it, when the software tried to copy the file(s).
The software use the standard 'tmp' folder as reported by the system's API.
This is normally a user specific folder.
xedni
Post by xedni » Thu Jan 18, 2018 10:26 am
So what do you recommend that I do to solve the problem? I have over 20GB in my home folder so I don't understand the error.
00:20:21: can't write to file descriptor 10 (error 28: No space left on device)
00:20:28: can't write to file descriptor 10 (error 28: No space left on device)
00:20:30: can't write to file descriptor 10 (error 28: No space left on device)
00:20:35: can't write to file descriptor 9 (error 28: No space left on device)
00:20:35: Write error on file '/tmp/~publish/images/oferta_Text2_bkgrnd.png' (error 28: No space left on device)
00:20:35: failed to flush the file '/tmp/~publish/images/oferta_Text2_bkgrnd.png' (error 28: No space left on device)
00:20:36: Write error on file '/tmp/~publish/images/img0011.png' (error 28: No space left on device)
00:20:36: failed to flush the file '/tmp/~publish/images/img0011.png' (error 28: No space left on device)
00:20:36: can't write to file descriptor 10 (error 28: No space left on device)
00:20:36: can't write to file descriptor 9 (error 28: No space left on device)
Post by Pablo » Thu Jan 18, 2018 6:20 pm
Did you try to clean the 'tmp' folder?
Did you run a disk utility to check for possible security or other errors?
This is not directly related to the software. It only tries to copy files to the folder and for some reason this fails.
The software cannot recover from such an error, it cannot repair disk errors or bypass system restrictions.
xedni
Post by xedni » Thu Jan 18, 2018 7:58 pm
OK I've worked it out. The software creates a tmp folder in my root file system when publishing, instead of my home folder. I don't have enough space in the root file system, but I have a lot of free space in my user home. How do you change the location of the /tmp folder the software uses?
Post by Pablo » Thu Jan 18, 2018 9:23 pm
The location of the tmp folder is reported by the system. It is implemented in the core of the development toolkit.
I have no control over this location.
