Trouble with php contact form
brandariy
Post by brandariy » Sun Oct 12, 2014 2:55 pm
What am I doing wrong
Advice please? what I'm doing wrong. The problem is that if the page on which there is a feedback form with php processing, in the header i have some symbols:
$value) { if (!in_array(strtolower($key), $internalfields)) { if (!is_array($value)) { $message .= ucwords(str_replace("_", " ", $key)) . " : " . $value . $eol; } else { $message .= ucwords(str_replace("_", " ", $key)) . " : " . implode(",", $value) . $eol; } } } $body = 'This is a multi-part message in MIME format.'.$eol.$eol; $body .= '--'.$boundary.$eol; $body .= 'Content-Type: text/plain; charset=ISO-8859-1'.$eol; $body .= 'Content-Transfer-Encoding: 8bit'.$eol; $body .= $eol.stripslashes($message).$eol; if (!empty($_FILES)) { foreach ($_FILES as $key => $value) { if ($_FILES[$key]['error'] == 0 && $_FILES[$key]['size'] <= $max_filesize) { $body .= '--'.$boundary.$eol; $body .= 'Content-Type: '.$_FILES[$key]['type'].'; name='.$_FILES[$key]['name'].$eol; $body .= 'Content-Transfer-Encoding: base64'.$eol; $body .= 'Content-Disposition: attachment; filename='.$_FILES[$key]['name'].$eol; $body .= $eol.chunk_split(base64_encode(file_get_contents($_FILES[$key]['tmp_name']))).$eol; } } } $body .= '--'.$boundary.'--'.$eol; if ($mailto != '') { mail($mailto, $subject, $body, $header); } header('Location: '.$success_url); exit; } ?>
Please tell me what to do. Looks like something in the settings, although I do miss all the instructions
Re: Trouble with php contact form
Post by Pablo » Sun Oct 12, 2014 3:41 pm
Did you set the page file extension to php?
Did you publish the page to your website?
See also the Form FAQ:
brandariy
Post by brandariy » Sun Oct 12, 2014 3:49 pm
thanks i am allready fix it problem& it is realy php
Users browsing this forum: No registered users and 2 guests
