Form wizard templates
Re: Form wizard templates
Post by mexman » Wed Oct 22, 2014 4:48 pm
support wrote:Did you start the software from the application folder?
If you started it from a shortcut then did you make sure the working folder is the application folder?
Hi Pablo..... I am starting QnEWB via a Desktop shortcut.
forms.dat is in the same folder as the software.
I tried to do it different... Started QnEWB out of the folder where the software lies.....then the forms.dat is loaded.
How can I fix it_ Where should forms.dat be_
Post by mexman » Wed Oct 22, 2014 6:00 pm
Solution
forms.dat must reside on the desktop from where QnEWB is started via shortcut.
Post by Pablo » Wed Oct 22, 2014 8:01 pm
Are you sure it's a shortcut and not a copy of the executable?
If yes, did you verify the working directly?
Post by mexman » Wed Oct 22, 2014 9:44 pm
1. forms.dat in the same directory as QnEWB (program file) -> No good
2. forms.dat in the worlking directory (where the xxx.qwk files are) -> No good
3. forms.dat on the desktop (where the link/shortcut to QnEWB program files lies) -> Working.
and YES, the shortcut/link is a shortcut/link, no executable!
Post by Pablo » Thu Oct 23, 2014 6:38 am
I'm sorry I'm afraid there is nothing I can do to change this. The file must be in the working directory otherwise the software cannot find it.
Post by mexman » Thu Oct 23, 2014 1:11 pm
What do you mean by "Working Directory"?
The one, where the qwk-files are or the one where the program ist located?
Post by Pablo » Thu Oct 23, 2014 3:05 pm
The working directory is the folder when the application is located (Not the shortcut, but the folder with all supporting files).
Post by mexman » Fri Oct 24, 2014 2:04 pm
support wrote:The working directory is the folder when the application is located (Not the shortcut, but the folder with all supporting files).
This is not happeneing here.
I need forms.dat in the folder from where I start QnEWB, in my case the Desktop, because I start QnEWB from there via Shortcut.
If I remove forms.dat from the Desktop. it will not be found, even if it is lying in the working directory as well.
MIchael
Post by Pablo » Fri Oct 24, 2014 3:31 pm
I'm sorry I do not have control over this.
If the system reports the wrong working folder then the software cannot find the file.
Post by mexman » Sat Oct 25, 2014 2:42 am
support wrote:I'm sorry I do not have control over this.
Yes I am aware youy might not be able to change that and I found a workaround.
(This seems to be the neagtive effect of not INSTALLING the software but DOWNLOAD AND COPY TO A FOLDER.
So the system is not really aware of the locations.
Anyway this non-solveable restraint might be important for others to know.
Users browsing this forum: No registered users and 2 guests
