Checkboxes and Radio Buttons
liam2015
Post by liam2015 » Mon May 18, 2015 3:49 pm
I am using the latest version of Q'n'E Web Builder on Mac.
I have tried creating a form following tutorials in numerous ways, inclduing using the build in form wizard and templates. The form works and appears correctly (inc. the checkboxes and radio buttons), but when I receive the values via e-mail, it only shows the values for text entries.
E.g. if the form contains
Name - text entry
Email - text entry
A - Checkbox
B - Checkbox
C - Checkbox
Submit - submit button
The e-mail returned, only shows Name and Email.
Any ideas? I've tried using a template, creating my own form etc.
Thanks,
Liam
liam2015
Re: Checkboxes and Radio Buttons
Post by liam2015 » Mon May 18, 2015 4:03 pm
Update:
I have been experimenting further. If I set names for each radio button and or checkbox, then it returns the value of the last selected radio button or checkbox, but nothing of the others.
e.g If I have 3 checkboxes names CB1, CB2, CB3, the email shows 'CB3: on'
I still can't get it to return the value of all checkboxes (preferably) or radio buttons.
Thanks,
Liam
liam2015
Post by liam2015 » Mon May 18, 2015 4:42 pm
SOLUTION (sort of):
I'll leave this post for anyone with the same issues.
First, ensure the checkboxes and radio buttons are named. To do this, select a single checkbox / radio button, go to the property inspector pane and under miscellaneous section enter a unique name e.g Checkbox1. Do this for all checkboxes and radio buttons.
Second, ensure that all elements of the forms are on the form layer itself. The other issue I had was that for some reason not all checkboxes were attached to the form layer, they were place above by the wizard, but not integrated for some reason.
Once I had done this is all worked OK (well so far - fingers crossed).
I hope this helps someone else,
