Write text field to a file on webserver
stubones99
Post by stubones99 » Wed Oct 07, 2015 12:10 am
I am trying to make the marquee be editable, so that it retrieves the text from a text file on the web server.
<div style=" width: 99%; overflow: auto;"><marquee behavior = "scroll" direction = "up"><object type="text/html" data="marquee.txt" style="width:100%; height:200px; margin:1%;"></object></marquee></div>
This code in a html box makes the marquee and will retrieve the marquee text from the designated marquee.txt file.
What I want to do now is make another web page where I can edit the text in a text box and when you hit submit, it saves the text back to disk using marquee.txt filename on the web server.
What do I need to do on Q&EWB to do that?
Thanks!
stu
Re: Write text field to a file on webserver
Post by Pablo » Wed Oct 07, 2015 6:35 am
This cannot be done with HTML only.
This requires (PHP) programming.
Post by mexman » Tue Oct 13, 2015 3:52 am
I guess you can do that, using the Newswriter extension in Plain Text Mode.
Did not heck it though.
