Free template: Simple modern
In this section you can share templates you've created with other users of Quick 'n Easy Web Builder.
filmphotog
Post by filmphotog » Wed Oct 07, 2015 7:36 pm
Free Quick 'n Easy Web Builder template: Simple modern
This template is a one-page layout with navigation between bookmarks. Perhaps someone is interested in using this template as a start and continue to modify the page.
Terms of use: Free
Extensions needed: Smooth Scroll II 2.6.0 (included in the template zip file)
No licensed images were used, the pictures were taken by me and are free to use.
Responsive Web Design
- 5 breakpoints, 320 480 640 768 960
- CSS Menu
- Activate social media links in the Image Map properties
- Master Frame is used for simplicity
- One-page layout
Fully functional demo
Template for download
Hope this template is useful, thanks.
Re: Free template: Simple modern
Post by Pablo » Wed Oct 07, 2015 8:20 pm
Great work! Thanks for sharing!
yolandalyons
Post by yolandalyons » Sat Oct 31, 2015 12:11 pm
Great work !
This template is looking nice can modern I must say ..
Being a web designer ,I prefer to design to 100 % custom websites that are now more in demand these days .These website are very much SEO friendly and can be changed easily compared to template site .View here my previous work .
filmphotog
Post by filmphotog » Sat Oct 31, 2015 1:12 pm
yolandalyons wrote:Great work !
Hi, and thank you very much for your comments! Yes I believe web design can be easy.
saroyan
Post by saroyan » Thu Nov 05, 2015 2:04 pm
Hi! Thanks for posting the templates.
Really nice!
How do you to get the smooth scroll to work?
Can´t figure it out? Do you have to install the smooth extension?
I did that, but what do you do after?
The red x-marked (do not publish) master frame is it supposed to be red x-marked?
Thanks in advance!
(Må så gott!)
Peter
filmphotog
Post by filmphotog » Thu Nov 05, 2015 2:57 pm
saroyan wrote:Hi! Thanks for posting the templates.
Really nice!
Thanks in advance!
(Må så gott!)
Peter
Thank you very much for the comments!
When opening the template the Smooth Scroll II is visible in the master_frame (if you installed the extension before opening the template). It just works, but to test it you could need to publish.
The red x is because the master_frame is included in the page html when publishing, the master_frame is just used at the design stage. Usually the master frame is useful when you have several pages and you place common objects like header and footer there. All pages can then use the same master frame. In this case it made the main page simpler.
saroyan
Post by saroyan » Thu Nov 05, 2015 4:28 pm
Hi!
Thanks a lot, now it works fine!
I opened the template after installing the extension.
Great work!
saroyan
Post by saroyan » Thu Nov 05, 2015 7:31 pm
Another thing though... the menu on top...i can´t seem to find it in the editor?
don´t find it in the object manager either?
thx
filmphotog
Post by filmphotog » Fri Nov 06, 2015 6:18 am
saroyan wrote:Another thing though... the menu on top...i can´t seem to find it in the editor?
thx
The menu is in the master frame, see "master_CSSMenu1". It should be in the object manager.
I always add "master_" in front of all objects in the master frame, this is to avoid duplicate ID's in the other page(s).
