Transparent background to a link
Post by moris » Fri Aug 18, 2017 10:27 am
Hey,
I was wondering how can I make a transparent background color for a text link. Please see screenshot: http://imgur.com/V7gaEXb
Thanks!
Re: Transparent background to a link
Post by Pablo » Fri Aug 18, 2017 1:41 pm
(new) links styles are transparent by default. Only if you set the background color, it will have a solid background.
Note: based on the screenshot it looks like you are using an old (unsupported) version.
Post by moris » Fri Aug 18, 2017 2:42 pm
I don't really have money to buy again the software. Is there something we can do regarding this?
Post by Pablo » Fri Aug 18, 2017 5:00 pm
If you create a new hyperlink style then it will be transparent, unless you select a background color yourself.
Post by moris » Fri Aug 18, 2017 7:31 pm
Thanks Pablo!
