Both versions on the same Macbook
johnrvd
Post by johnrvd » Mon Sep 25, 2017 9:22 am
I have your Mac App Store 4 version on my Macbook. I have your website 5 version on another Macbook and would like to have it on the same Macbook as the Mac App Store 4 version. Is there any software conflict having both installed? I don't need to run them at the same time. Thanks.
Re: Both versions on the same Macbook
Post by Pablo » Mon Sep 25, 2017 11:06 am
Both versions have different working folders, so they can be used on the same computer.
Note however that if you save your project in version 5 then you can no longer open it in version 4.
