email and mobile
Jonas
email and mobile
Post by Jonas » Sun Oct 29, 2017 12:18 pm
Hi. A few questions. I am using blocks as for contact us form. Webpage" www.mj360.com.au". People fill up the form (as you see theres one more problem - name, email, message words doesnt fit their spots), they press send message and nothing.. Coz I dont know where to fill my server details? I suppose they fill up the form press send message and I get their message to my email with their details? I like this block, but maybe i should use different one if its not possible so?
Other question, I am playing with breakpoints, I do have default one, 768, 320. But on mobile phone it just cuts a lot of info.. Missing contact form etc.. Y axis is 8200 so its not that..
Re: email and mobile
Post by Pablo » Sun Oct 29, 2017 9:05 pm
You have not configured the form properties. Currently you are using 'mailto' which is not a very reliable way to process the form.
http://www.quickandeasywebbuilder.com/f ... f=10&t=135
To process the form you will either need to configure an external form process or use the built in form script.
It looks like you have hidden the form in your breakpoint(s).
Note however that I cannot see what you have done exactly based on the HTML code only.
To be able to help you I need to see your project settings.
Jonas
Post by Jonas » Mon Oct 30, 2017 9:38 am
Ok. Got that. Probably will make brand new project.
One more thing. I am using Photo Gallery for my portfolio which looks good and is easy for breakpoints. But, can I link pictures in it? Cant find it. Would be great I could.
Post by Pablo » Mon Oct 30, 2017 5:41 pm
The photo gallery was designed to display a larger version of the same image. You cannot link to another image.
Related tutorial:
http://www.quickandeasywebbuilder.com/photogallery.html
