WWB -> QnE
Mainzelmann
WWB -> QnE
Post by Mainzelmann » Tue May 29, 2018 1:40 pm
Hello,
I want to switch from WWB to QnE. Unfortunately the import doesn't work.
The following error message appears during import:
Expected chunk item of type 'string' but got type 'i'
I'm using at the moment:
Version Linux Mint 18.3 Sylvia 64-bit, Quick and Easy Web Builder 5.4.0 for import
and WWB 14.0.2 (trial)
I licensed version 10 from WWB. But I would buy wwb 14 immediately if the export/import works.
translated with deepl german- english
Translated with www.DeepL.com/Translator
Re: WWB -> QnE
Post by Pablo » Tue May 29, 2018 3:38 pm
Not all objects are supported by QnE.
Please see the help for known limitations of the export tool.
Mainzelmann
Re: WWB -> QnE
Post by Mainzelmann » Wed May 30, 2018 12:42 pm
Thanks for the answer,
I can't find the information about the restrictions. Is the information in the help of WWB or QnE? Maybe there is a link there !?!?
Übersetzt mit www.DeepL.com/Translator
Re: WWB -> QnE
Post by Pablo » Wed May 30, 2018 2:19 pm
In the help of WWB14 go to Content -> Menu Options -> File -> Export to Quick 'n Easy Web Builder -> Know limitations
