*** SOLVED *** Installation on Ubuntu 18.04 does not work
rdeanw49
Post by rdeanw49 » Fri Jun 08, 2018 1:26 am
Installed latest Quick and Easy Web Builder on Ubuntu 18.04 using deb file. Icon appears in applications, but clicking results in no response. Installed Microsoft Core Fonts as well as other recommended libraries for 64-bit systems. Any suggestions?
Re: Installation on Ubuntu 18.04 does not work
Post by Pablo » Fri Jun 08, 2018 6:05 am
What is the error message when you try to launch the application via terminal?
Maybe this will be helpful?
Or
http://www.quickandeasywebbuilder.com/f ... =5&t=44747
rdeanw49
Post by rdeanw49 » Sat Jun 09, 2018 12:31 am
Running qnewb from command line returns: ./qnewb: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory. Search using Synaptic does not show any results for libpng12.so.0. Have tried all of the other posted suggestions you referred to.
Randy
Post by Pablo » Sat Jun 09, 2018 6:46 am
You will need to install libpng12.so to make it work.
rdeanw49
Post by rdeanw49 » Sat Jun 09, 2018 1:31 pm
Apparently the package for libpng12.so is not available in Ubuntu 18.04. However you can get it here: https://packages.ubuntu.com/xenial/i386 ... 0/download. You also will need Font Awesome which you can find here: https://packages.ubuntu.com/trusty/all/ ... e/download. Be sure to get the i386 version of libpng12.so. Everything works once the above packages are installed.
Thanks,
Randy
Post by Pablo » Sat Jun 09, 2018 4:59 pm
Ok, thanks for clearing that up!
Post by mexman » Sat Jun 09, 2018 7:52 pm
Hi Randy!
You made my day! Just stumbled across the same problem! (Having WINE setup problems also with 18.04 ;-)
Thanks for sharing the solution!
