A couple of quick questions
dchaley369
Post by dchaley369 »
I have V6 now and am about to overhaul yet again my sites.
I have 2 quick questions to ask.
1) I must be missing something but it used to be that when you first opened the program it remembered your window size and for the last couple of versions it seems to always open in full screen. How if I can change that back to remember the previous size?
2) Again, I must be missing something. When opening the program it used to remember the site you were working on when you quit and would auto open it again. Now I get the blank screen to start a new project. Is there a way to set auto open the site that you were last working on.
I have looked in the help many times trying to find these answers but to no avail.
Chris
Re: A couple of quick questions
1. This functionality has not changed. This feature did not (intentionally) exist in previous versions.
2. Also, this behavior has not changed. There was never an option to re-open the project.
Maybe you are confusing the application with with WYSIWYG Web Builder?
