Responsive Design help
uniquecelebrant
Post by uniquecelebrant »
Hi there,
I am struggling with bits of responsive page design.
In the tutorials, object manager shows tick boxes for visible and locked for all objects. These do not appear in mine? I. only. get right click options like hide object and hide in other breakpoints.
Am I missing something blindingly obvious?
Many thanks
Paul
Re: Responsive Design help
Where exactly did you see this?
The object manager in the Mac version does not have checkboxes, but you can use the context menu to change the visibility.
uniquecelebrant
Found it. in one of your posts, also in the attached video
To learn more about responsive web design I strongly recommend to read these related tutorials:
Responsive Web Design
http://quickandeasywebbuilder.com/respo ... esign.html
Guess that is the Windows version. Many thanks for the reply
