Themeable menu text color
Ton
Post by Ton »
I am trying to change the text color of the clickable-active-state of a themeable menu, but instead the text color of the content gets changed.
At first the colors seems changed in the properties, but if I click somewhere else and select the themeable menu again, the clickable-active-state has its original color again and the content has the color that I selected for the clickable-active-state.
How can I change the text color of the clickable-active-state?
Re: Themeable menu text color
You are right, this currently does not work correctly.
It will be fixed in the next update.
Ton
Post by Ton »
Ok, thanks. I've noticed someting else. I can't change the text color in a card with more colors. Only with one of the default colors.
I was not able to reproduce this. Can you please be more specific?
Ton
Post by Ton »
Yes, when I add a card with a text item, I click on Edit, then Color, then more colors.
When I enter a hex code (for instance 1F4586) and close the dialog window, this is ignored and the text still has the original color.
It works correct for me.
Which operating system do you use?
Do you have the same problem with other color items?
Ton
Post by Ton »
Hi, I use Mac High Sierra. I can change all the other text colors with a hex code, only not the text color of text in a card.
Have you tried it on Windows?
It looks like this is currently not supported on the Mac, it works on Windows.
I will investigate if this functionality can also be added to the Mac.
Ton
Post by Ton »
Ok, thanks!
