Link with Copy to Clipboard
Hey,
I was wondering if it's somehow possible with Quick 'n Easy Web Builder to have a Link which also copies a value / parameter to the Clipboard.
This can be found on Coupon Sites for examples (as a reference).
Thank you,
Re: Link with Copy to Clipboard
This requires a script and it not specific to Quick 'n Easy Web Builder.
For example:
https://www.w3schools.com/howto/howto_j ... pboard.asp
Issue solved.
Thanks.
