Shapes and Breakpoints
Hey,
I haven't clearly understand how I am supposed to work with Shapes and Breakpoints.
If I insert a Shape -> Unhide it on breakpoint -> Resize it to match the breakpoint screen size. Can that work? Or should I define different shapes per Desktop and Breakpoint?
Thanks.
Re: Shapes and Breakpoints
Shapes are not responsive, so they cannot have a different size in breakpoints.
If you need a different size then you will have to clone shape.
See the FAQ 'Which objects are not responsive?'
http://www.quickandeasywebbuilder.com/f ... 10&t=43085
Thanks for the reply,
It says: (*) Shapes and Logos can be made responsive if you set the output format (publish) to 'CSS3'
Are there any Cons of using CSS3 shapes instead of images?
When published as CSS, shapes only support rectangle, rounded rect and ellipse.
See also the help.
