Release 6.2.3 change my top master page
@pps4me
Post by @pps4me »
I have a master page that are used on every page at the top under my URL. Every page that I have changed with release 6.2.3 change this master page so that the width is a fixed value instead of 100%. But I can't find any change on the parameters for this object.
My ULR is https://www.pps4me.com
All pages a okay, except these:
https://www.pps4me.de/macOS.html
https://www.pps4me.com/apps/qr.html
Re: Release 6.2.3 change my top master page
It looks like you have placed a layer inside a layout grid, this is not correct.
A layer is an absolute/fixed container, it cannot be used inside a flexible container. This defeats the purpose of the layout grid.
Note that it is very difficult for me to see what you have done exactly based on the HTML code only.
To be able to help you, I need a copy of the project file.
