Adding more FontAwesome
Hey,
I can see there are some missing FontAwesome icons in the software and I was wondering if there's a way I can manually add more FontAwesome icons?
Thank you.
Re: Adding more FontAwesome
All (free) FontAwesome icons are included. The paid icons may not be included.
If you want to add additional icons then you can create your own icon font library.
Related tutorial:
http://quickandeasywebbuilder.com/iconfonts.html
On what folder should I place the additional icons? I can not find such folder: /Documents/Quick 'n Easy Web Builder/
Go to Preferences -> Backups and make note of the backup. This is also where all other QWB related files are located.
Icon libraries are in
/Documents/Quick 'n Easy Web Builder/iconlibraries
My back up folder is in: /Users/morbabi/Library/Application Support/Quick 'n Easy Web Builder 7/
I can't find iconlibraries anywhere here.
Maybe you did not add libraries any yet? In that case the folder will be empty.
Related tutorial:
How come other free fonts of Font Awesome are not in the software? Such as this one: https://fontawesome.com/icons/hamburger?style=solid
The software includes FontAwesome 4, because FontAwesome 5 has a different license.
