Hi Pablo:
The description to TOASTs in the help file is still very small, here a few questions:
What does the cookie related to a toast do? Does it avoid reappearance after closing the toast?
Can I trigger actions on "close toast"?
Can "close toast" be used with a link?
I want to use a toast as a "Acknowledge the page may use cookies"-message and after closing it, the user should be redirected to the main page and the toast should not appear for some time!
Toasts
Re: Toasts
yesDoes it avoid reappearance after closing the toast?
No, there no event for this.Can I trigger actions on "close toast"?
NoCan "close toast" be used with a link?
Re: Toasts
Thanks for the quick answer.
So I guess I need to build the function/message I mentioned with some other tool or can you think about any QnEWB function to use for that purpose?
Re: Toasts
It is possible with custom code. For example:
Note however that I cannot assist you with writing custom code.
Alternatively, you can try the dialog which does have a 'close' event.
<script>
$(document).ready(function()
$("#Toast1").on('hidden.bs.toast', function ()
// do something
</script>
Re: Toasts
>Alternatively, you can try the dialog which does have a 'close' event.<
Just trying.... but seems that different than the Toast, the "dialog" condition will not be remembered by a cookie.... it seems to appear always.
Is this possible or am I doing something wrong?
Re: Toasts
Thanks for pointing me in this direction, but it is not working as I like to. Seems that "//do something" is fired only when the toast has being hidden by the user but not if the toast is not even shown because the cookie has not expired yet.Pablo wrote: ↑Mon Nov 25, 2019 7:05 am It is possible with custom code. For example:
<script> $(document).ready(function() { $("#Toast1").on('hidden.bs.toast', function () { // do something }); }); </script>
Re: Toasts
Correct.Seems that "//do something" is fired only when the toast has being hidden by the user but not if the toast is not even shown because the cookie has not expired yet.
See also:
https://getbootstrap.com/docs/4.3/components/toasts/
