Carousel positioning with flexible width
reinecath
Post by reinecath »
I'm having problems re-positioning the carousel when flexible width and cube animation is used. I tried changing the vertical position in the property inspector and also tried dragging/resizing in the gui. But it seems to resist repositioning (vertically in the page). I need a buffer between the header and the carousel for a marquee. Should I place the marquee first or is there some way of repositioning the carousel that I haven't figured out yet? Thanks. BTW, great software.
Re: Carousel positioning with flexible width
A 'flexible' carousel cannot have an absolute position because it's a floating element (like layout grids and flexbox) .
But you can rearrange floating element with the 'Arrange tools' (move to front, move to back, etc)
See also:
https://www.quickandeasywebbuilder.com/ ... modes.html
reinecath
Post by reinecath »
Thanks again for the quick response. That worked as did a more judicious use of the layer object.
