Carousel and Text
Carlito
Carousel and Text
Post by Carlito » Wed May 18, 2016 7:37 am
Hi everyone,
Thank in advance for your help
I read posts about Carousel and i did not find the answer to my problem, but you probably have the answer :- )
I would like to know if it's possible to switch text when a slide is switched.
For example when the slide 1 is shown, text 1 is shown, when slide 2 is shown, text 2 is shown...
I tried some events to know when a slide is started and show the text attached to the slide. But I guess I failed in this try.
An other way but not the best, is maybe to insert text in the image of the slide, but it'll be really a shame or maybe the last solution :-/
Thank you for your time
Re: Carousel and Text
Post by Pablo » Wed May 18, 2016 8:48 am
filmphotog
Post by filmphotog » Wed May 18, 2016 8:57 am
I also just tested a Carousel with different text object for each slide. The different image needs to be visible to add the text to it. I double click the image in Object Manager and hide/unhide to go to the next slide with the Carousel buttons.
Carlito
Post by Carlito » Wed May 18, 2016 9:25 am
Thank you for your answer ;)
My question seemed to be thoughtless but it seems I failed in my search. My bad °-°
This note helped me to understand two things.
First i won't use shapes (non responsive good to know )
Then i didn't know that to show a hidden object, it has to be shown with effect (ShowWithEffect). In this way i learned a lot this morning : O
Thank you again for your time and your help
