Text position which changes
Post by moris » Sat Aug 19, 2017 5:10 pm
Hey,
I have this page: http://www.movetotlv.com/TransportationMenu.html
and the problem is that I am trying to build a menu which the text I added to it moves with it.
How can you produce it?
Open the headers at the top and you'll see it's hidden the text I added in the middle. Is there any solution for this?
Thanks!
Re: Text position which changes
Post by Pablo » Sat Aug 19, 2017 5:13 pm
I'm sorry, but it is not clear what you are trying to do.
Can you please be more specific?
Post by moris » Sat Aug 19, 2017 8:49 pm
Sorry.
As you can see on the link I have a menu and a text on it. If you open one of the headers then the text doesn't move together with the items.
I was wondering if it's possible to make the text position depend on the menu position. if not is there any alternative to what I am trying to do?
Post by Pablo » Sun Aug 20, 2017 7:11 am
No, that is not possible.
But maybe you can use an Accordion instead?
