Problem with link background
chainho
Post by chainho » Tue Sep 05, 2017 5:17 pm
Hi Pablo. I have a problem regarding links: can´t do transparent background anymore even when i create new ones. What i´m doing wrong?
http://www.academiamusicaonline.com/experience/
Re: Problem with link background
Post by Pablo » Tue Sep 05, 2017 6:04 pm
Links are transparent by default. Only if you set the background color, the background will be solid.
To reset the background color to transparent you will need to set the background to RGB: 254, 254,254
chainho
Post by chainho » Tue Sep 05, 2017 6:41 pm
Great Pablo. It actually solve the problem. Thank you for your support.
Jorge Chainho
