Forms blocks
eosdng
Forms blocks
Post by eosdng »
Hi I am glad, that i found this awesome piece of software to build my entire wedding photography page. However, despite working and learning for 3 days, i have some minor unclarities.
blocks forms
I did drag and drop a very nice blocks forms for the client, to fill in their contact info. When i want to reposition the block, it always goes to the same place, like it would stick there. If I do build one myself with the forms wizards, i can position the forms wherever I want.
How can i reposition the ready made forms block? I did not find anything, to turn on or of on the property inspector.
Thank you
Re: Forms blocks
Most predefined blocks use layout grids and therefor are floating, otherwise they would not be flexible.
Floating objects are automatically arranged from the top to the bottom of the page, depending on their order in the Object Manager.
Layout Grid FAQ:
viewtopic.php?f=10&t=43910
To learn more about different layout methods please read this related FAQ:
viewtopic.php?f=10&t=44461
