Index of links, faqs, articles, videos - by topic
kgnoble
Post by kgnoble » Sun Jul 08, 2018 3:38 pm
Hi Pablo
I am having fun in finding my way around the software as a newbie, but find it confusing when looking variously at the manual, articles, faqs, examples and the odd video. I suspect I am typical in that I want to create a website but without the experience of having learned to code before. QnWB is excellent to be able to do that except I cannot easily find out how to.
Is there a master list of all text sorted by topic that would make it easier to refer when trying to make something specific happen.
As an example, the incidence of texts for responsive design is very widely spread and proved difficult for me to find and therefore very time consuming. In the end the video link was very useful - but now I can't even find it to refer to again or to see if there are further videos to aid my learning elsewhere.
Am I missing something that is available, or do you have any plans to create something. If it doesn't already exist, perhaps an excellent learning opportunity for me would be to create a website for such a resource.....
Best
Keith
Re: Index of links, faqs, articles, videos - by topic
Post by Pablo » Sun Jul 08, 2018 3:57 pm
You can find the 'official' tutorials here:
http://quickandeasywebbuilder.com/getting_started.html
The FAQ is available here:
http://www.quickandeasywebbuilder.com/f ... m.php?f=10
All other documentation can be found under the help menu.
And studying the example template may also be helpful.
http://quickandeasywebbuilder.com/templates0.html
I am not sure what else I can tell you about it...
But if you still have any questions then you can post them here on the forum.
