master frames need help
Robando
Post by Robando »
Hi all, I'm using ubuntu linux with latest version. I'm trying to create a template using master frames with this guide https://www.quickandeasywebbuilder.com/ ... frame.html It appears there is a variation in the windows and linux software (correct me if i'm wrong) and i think the guide is intended for the windows version?
So far i have made a master frame named master_frame. This page is set up as a master frame and contains header, content place holder and footer. The instructions tell me to go to a normal page and add master page objects however I can't find anyway to do this in the linux version.
Any help appreciated 8)
Re: master frames need help
There are no major differences between the Windows and Linux version.
Master frames work exactly the same.
You can set the master frame in the page properties.
Robando
Post by Robando »
Hi Pablo, my mistake both OS versions are identical.
I'm still struggling with the master frames Step 4 Switch back to the index page (click on the index tab) and insert an Master Page object.
When i preview the index page the master page contents are not displayed.
Thanks for the help.
Robando
Post by Robando »
It's working now i didn't set the page for master page on the index page.
