Hello,
As a long time user of your software, I have to note after several days of trying and failing that, in my opinion the system of Flexbox container, flex Grid, Layout Grid components is practically unusable on QWB. I don't pretend to be an expert in this matter, but even using the examples I can't make anything correct. And when I do, I don't really understand why it works.
For example, if I copy an element from one of your site examples, it works. But if I try to create it myself, it doesn't work the same. But all the settings are the same. This system seems inconsistent to me.
I can't list all the other problems I've encountered, because they are so numerous (lag, layout, WYSIWYG, ...). But it seems to me that the complexity of this system is disproportionate to the results to be obtained.
I wonder if someone has already used these components from scratch in the creation of a site using QWB ...
I specify that I use QWB on Macos.
Greetings,
Vincent Blanc
Flexbox container, flex Grid, Layout Grid ...
Re: Flexbox container, flex Grid, Layout Grid ...
There are no known issues with these tools. They have been available for years. If there where any known issues then would have already been fixed.
Basically, all templates have been create with these tools, so I am sure they work correct.
https://www.quickandeasywebbuilder.com/ ... s2020.html
Note that flexbox is a standard HTML feature. I agree that it can be confusing sometimes if you do not understand the concept. But this is not directly to the software.
This may be helpful:
https://www.quickandeasywebbuilder.com/flexbox.html
If you need assistance then please share a demo project so I can see what you have done.
https://www.quickandeasywebbuilder.com/ ... 10&t=45024
