Light Box setup ignored
Please have a look at this page: https://ourvilla.net.au/stories.html
The 3rd item - with the image is linked to a video clip, I set it to open in a Light Box, it does.
But when I tried setting the light box to be : width:640,height:385 - it is ignored and it comes smaller
What is the other option "Value" for? It is grayed out
Re: Light Box setup ignored
Each lightbox has its own settings. The settings you have used are for fancybox only.
prettyphoto has different options:
http://www.no-margin-for-errors.com/pro ... umentation
I have this object placed on the page
I do not see where did I "Select" which type of Lightbox to use?
I am clicking on the Link symbol on the top menu bar, I select "Target" - Open in a Light Box
What else should I do?
You can select the lightbox type in the page properties.
Thanks, ok now
