label for radio button or Checkbox
In my Windows days, I use to attache a lable to those objects, but it seems in QAEWB this is not an option, or maybe I am missing something, so I ended up placing the checkbox in one column of a Layout Grid, and the text in the other
Hope someone can clarify this for me
Re: label for radio button or Checkbox
You can use the 'label' object to associate a label with a form element (via the 'for' property).
Note that elements will still be two separate elements, labels are mainly for screenreaders/robots.
If you want both elements on the same row, then uncheck the 'full width' option.
OK, will try that
Thnaks
